ok guys I picked up a D44 out of a 78 fs bronco but I bought the cage 5.5 progressive rate spring for the front. My problem is what to do, to correct my pinion angle with cast wedges. I pulled radius arms out of a junk yard and the axle is still there so i'm wondering should I stick with what i've got now or can I go back and swap my disc setup off of the 78 and switch it to the 76 axle in the junk yard.
If I can make my 78 work I would rather do that. ground clearance is critical for this rig "rock crawler only".
							figured it out
				breefee_BII
early D44 converted to late model D44
IF YOU GOT IT BREAK IT
