Got new U-joints and started putting the front drive shaft in. Discovered that my front diff is blown. Needs a new ring and pinion as well as a pinion bearing. Didn't get to finish the install as my torx bit broke off in the bolt. I'll fix the bolt, install the drive shaft, and just use the truck in 2WD until I can afford to rob the front off an Exploder.
Other than that, it's done.
1985 B2 project
Re: 1985 B2 project
Sic Transit Gloria Mundi
Illigitimus Non Carbarundum
1985 Bronco2
1958 Willys CJ5
1985 Bronco2
1958 Willys CJ5
