My bronco ll switch
didittwice
Re: My bronco ll switch
Ok after some head scratching, I turned it over came alive of corse it had no muffler on but sound good, now to hook up the rear drive front drive check the fluid level, bleed brakes and clutch and then turn it around and pull the gas tank and hatch and replace them.
didittwice
OK all in
Inside and out
Inside and out-
didittwice
I just did not know this was here
didittwice
I got this at the part it is safe and works pretty good
Looking good..
didittwice
Thanks and drove it around the block and it went nice the wife loves it and thats good it is hers.
didittwice
Ok the hatch is on
didittwice
Ok he is the fuel tank hope it will be in soon
didittwice
Blast my big tank will not work with out mod. to take the in tank pump Blast.
It was set up for the two pump that was in the 86 Blast again.
OK on to bigger and better all that is left is the ebrake cable driver side and leaf spring hope to find tomorrow? then it burn up the highway..
didittwice
OK now get these bad boys in and the will do it for awhile
didittwice
OK it is ready for now as soon as the insurance company calls and then tags and off we go.
