need help
There is a unused connector under the hood that you have to use a couple of jumper wires on with a analog volt meter. You count the sweeps of the needle to get the codes. I don't have them with me but they are usually in your repair manual.
you can pick up a code reader from most parts stores for around $40.00 or go here...
http://fordfuelinjection.com/?p=13
jumper and read the flashes on the check engine light. it should flash codes similar to a code reader would do with the LED light.
						drive your truck to Autozone and they will pull the codes for free...
				baby bronco
				baby bronco
