front wheels tip in
				wakefieldracing
The safest way is to remove the spring an add your spacer to the bottom of the spring mount. It should slip over the stud, used to hold your spring down. I won't go over an inch of spacer though. Do not use twist in spring spacers or the adjustable ones that use abolt and some hooks to spead your springs apart. Eventually you will break them. I made my spring spacers out of an one inch plastic, that I cut out with a hole saw, and then drilled the centers to fit over the spring hold down stud. There is enough stud hanging out for one inch.
