drewski15
Posts: 25 Joined: Wed Mar 01, 2006 5:33 am
Post
by drewski15 » Sun Mar 12, 2006 9:43 am
anyone ever thought of a way to put an electronic choke switch in the cab? i think it would be pretty cool after switching to duraspark.
"Dont call him a cowboy until you've seen him ride"
Posts: 2233 Joined: Sun Apr 18, 2004 6:38 pm
Post
by Nobody » Mon Mar 13, 2006 7:35 pm
I don't see a reason not to just use the stock style electric choke. My Bronco's are one pump and start, even in the dead of winter.
However, you could probably use a throttle solenoid or a vacumm controlled motor that's often used on heater valves. Or just get a manual choke kit that uses a cable.
drewski15
Post
by drewski15 » Mon Mar 13, 2006 8:52 pm
yea i think that is what i will end up doing i just thought it would be a cool idea.
Posts: 743 Joined: Sat Jan 01, 2005 8:10 pm
Post
by ranger5.0 » Tue Mar 14, 2006 8:18 pm
It should take a constent 12 volt source that is activated when the key is on. You really shouldn't need a switch.
