what should i put under my b2
gullion_a86
Post by gullion_a86 »
I'm doing an axle swap and want to know your guys opinion on what i should put under there. I'm putting a 302 and I want some good reliable axles.
How do you intend to use your Bronco II?
nuff said :eek:
gullion_a86
do yall think two dana 44s would work? or a d44 in front and a 9" in rear?
how do you intend to use your BII?
i run a dana 60 in the front and 10.25 in the rear.
broncoo
Post by broncoo »
like nobody said how ya gonna use it?
gullion_a86
nothing too serious. Just trail riding and mudding
Ok then, what size tire do you plan on running? Do you plan on installing lockers?
MikePotts
Post by MikePotts »
i think the guys are trying to get the variable from you to pinpoint the right setup for what you want. but, you may decide to get more serious later.....think about it , it happens to us all. plan for the future! i am not saying get Rockwells! but, make sure whatever you get will standup to whatever you MAY decide to do. i am doing the SAS with EB axles (Dana 44 and 9") many have done it, and been satisfied with it, these will handle whatever size tires you want (within reason) and the swap is fairly simple.
just my .02
mike
