I've been busy.....
DZK007
I've been busy.....
Post by DZK007 »
I asked what ye'all thought about my explorer style rear diffy swap and I think it turned out better than expected.
I dropped the springs down under the frame using two sets of frame mounts from an explorer. The spring packs are almost stock and a pair of custom mounted Rancho RS9000 shocks work pretty well keeping the 8.8 diffy doing what it should.
I used a cheap set of James Duff traction bars for the bar link and hardware but I had to make custom mounting brackets. Not too hard with a torch and drill press.... man I love free iron!!!
This truck is real capable even with the 235-15" tires. I can't wait till I get some 33's for it.
The front has a 4" lift and the ground is level. I just thought someone might be wondering how it turned out......
410fortune Owes ME $$$ !
DZK007
Post by DZK007 »
The front of the spring.
mounting bracket from an '02
DZK007
Post by DZK007 »
Traction Bars. Gotta have em!!!
Homemade axle mount uses the original 7.5" diffy's sway bar mounts
DZK007
Post by DZK007 »
Shackle end. I used a pair of mounts from a '96 at this end of the spring with the stock BII shackles.
DZK007
Post by DZK007 »
The front....
Yup. no sway barz....
DZK007
Post by DZK007 »
While I had it apart I replaced the seats also.
At least the truck has a few redeeming qualities....
did you realy need the traction bars?
how did it do with out them?
most of the time traction bars limit the axle.
do you have any flex shots?
DZK007
It has lots of flex
Post by DZK007 »
The traction bars pivot from the front perch bolt of the spring and don't limit the travel a bit - just keep the diffy from wrapping the springs up and destroying the driveshaft. I jump it quite often (at least 10 times just today) and it lands real nice.
I'll see if I can get a couple flex shots soon but I don't have a digital camera.
Nice work :cool:
OCD4B2
Post by OCD4B2 »
Good job I like how it turned out. By the way, the size of those tires is pimp :cool:
no v8? why drive?
Post by no v8? why drive? »
can you get a pic of the front mount of the traction bar? The b2 I bought blew a rear end for the same reason and I dont want it to happen agian.
87 4X4 Ranger 306ci AOD NP205 fw d44/8.8 5.13s
94 4x4 Navajo 8" lift
DZK007
Post by DZK007 »
The mount I made is just some 1/8 wall angle iron with a hole in each face and bolted down with the spring eye bolt. Try to keep the spring eye hole as close to the angle wall as possible so the pivot point is as close to the spring's as is convenient. :redneck: Mine look pretty hack but they work......
I'm saving for some 32's and 4:56 gears. I'll run these till then.... :puke:
I wish I had a digital camera but right now I'm at the mercy of my soon to be ex-brother-in-law......
offroadohio
Post by offroadohio »
Hows the stability of it?
I kept eating u-joints cause of the axle wrap with the lift blocks. Sure could of used one of those. :D
DZK007
Post by DZK007 »
It runs real stable offroad but without swaybars it is a pig on the road. I'm going to get the front bar back on so I can run it on the highway to go to some trail runs and things without having to trailer it.
Yup! My last broken driveshaft is what pushed me to do this one.......
