lifting Q's, AGAIN
lifting Q's, AGAIN
well i fixed the outter axle shaft so i have 4x4 again..i installed the 2" Add-A-Leafs and i actually got 4" of lift. was i supposed to take some leafs out or something
i also installed the coils and tried to see if 3.125* camber bushings would correct it but they wont....ive seen these brackets for sell before for like $40-$60...i have $50 if anyone has some laying around or can track me down a used set...help would be much appreciated...the sooner the lift works the sooner i can come out and play with ya'll
they are bushings that sit between the knuckle and upper ball joint to change its angle. from what i understand the most change is 3.125* and that wont correct 4" of lift. is what you have different or what? the brackets im talking about are the pivot drop brackets. lemme know
no v8? why drive?
you cannot exceed 2" of lift without using drop brackets. The degree of adjustment needed at the knuckle to make up for a 4" lift is around 6 degree is which no one makes. you have to use drop brackets or drive around on the outside of your tires.....
87 4X4 Ranger 306ci AOD NP205 fw d44/8.8 5.13s
94 4x4 Navajo 8" lift
