ground wire issue
ground wire issue
I`m having a ground wiire problem. I turn the key and fuel pump doen`t work. I put a new fuel pump in. bought a new plug that you put together yourself. I put the tank back in. I also put a new relay in for the fuel pump. when I tried to jump start it one of the wires hooked to the selonoid started smoking.
Re: ground wire issue
Just throwing out a couple of suggestions here. First off is it possible you swapped the wires into the wrong side of the plugs. Also if that is not the case then look for a pinched wire between the pump connector and the pump. Do you have an ohmmeter available? If so check the resistance between the high and low terminals. it should be a low resistance but Not Zero resistance.
Check out the wire from tank to relay real close maybe your problem is there!
thank you I`ll check into trying those procedures to see if thats my problem
