confused on tires and rims
just installed 2" spacers up front and add a leafs in the rear. I was wondering what would be the the best sized rims and tires that wont rub or require any trimming. Thanks
Re: confused on tires and rims
Well considering I was a able to put 31/10.50/15 on my bonestock 87' b2, you should be able to fit a 33" on 15" rim with that 2" lift and it wouldn't require any trimming
33's will rub better off with 31's
Did you have any alignment issues with the blocks? MY camber is out of control. Sunday my ex takes the girls again and I may have to pull them out.
