Best way to Lift
BroncoII86
Best way to Lift
Post by BroncoII86 »
I have an 86 Bronco II and im interested in building or using exsisting vehicle parts to get 2-4 in of lift any ideas or suggestions??
Mud Addict
Re: Best way to Lift
Post by Mud Addict »
For cheap 2in lift, get the coils and leaves from an '91-94 4 door Exploder :D
BroncoII86
Thanks i was gonna use xj springs but keeping it all Ford sounds good :D do the leafs bolt right up? and what about alignment? i know i will need camber bushings
Mud Addict
Have to flip the centering bolt on the leaf springs, Exploders are spring under B2's are spring over. Other than that make sure your shocks are long enough to not limit your suspension travel :beer:
If trying for more than 2in lift it will require drop brackets for yhe front axle.
danboy282
Post by danboy282 »
Is it correct that he will need camber bushings?
Mud Addict
I did not need to when I did mine, but every Bronco is a 'lil different.
danboy282
Post by danboy282 »
Thanks, this will probably be my lift, at least for a little while.
