Window replacement
Window replacement
My '90 b2 was recently vandalized and the quotes i recieved on the rear driver side window were all around 1500-1700 dollars. Is there somewhere you suggest to find a better place or a differnet solution for replacing it?
- Mud Addict
Re: Window replacement
Very easy to replace the window your self, my last B2 I bought had no window. It cost me $20 at the junkyard, and $15 for the proper seal.
Yep, pretty simple swap out and you should find them plentiful.
Hi where were you able to find the rear window seals??
LMC Truck has window seals as well as a number of other parts houses.
