front main seal leak
do you know if the front main seal can be replaced by removing the balancer and pulling the seal out, or does the front engine cover have to be removed and the seal come out the back of it?
90 b2 4*4 5 spd 9500lb winch alum bumper, 31" tires
Re: front main seal leak
you can do it from the outside, there was a tool to remove it and install it. it's in deep.just kinda note where it is before you remove it.
thanks for the info and the picture
