clutch problem
clutch problem
i have 84 bronco ii the clutch has no pressure.ive been bleeding it at still have had no luck at getting any pressure from it,there is no leaks in the clutch line.dont know what to do need help
Re: clutch problem
Did it go away all at once? There is a black diaphragm in the reservoir that people forget to remove from the master when filling up. I may be wrong but I think I remember that the early B2's had a external slave cyl. Another thing to remember is to lift the pedal all the way up when bleeding. A easy way to bleed with an external slave is to push the slave back by hand. If the Master is bad then you're spinning your wheels. You can look at the firewal on the inside at master and see if it's leaking.
