Hey there...first post here...
First, I'm totally new to the bronco 2. I have the opportunity to pick on up cheap. I believe its in fair to good condition for its age, but its main issue is a failed freeze plug. Its the one located right up against the flywheel.
My question is, can that hard to reach freeze plug be replaced without yanking the engine? And is there anything specific to broncos that caused a freeze plug failure? The truck has just under 150k miles on it. It'll start and run but it'll blow oil like a fountain obviously.
I can get it for a song but I'd like to know if I'm gonna need a cherry picker and the whole nine to get it running...
Thanks guys, if I pull the trigger I'll be pestering you more often...
Freeze Plug Replacement...
Re: Freeze Plug Replacement...
StumpyJohnson wrote:Hey there...first post here...
Hmmm I am confused,
Freeze plug usually means one of the plugs in the water jacket.
think about it for a minute,hmmmmmmm,where is the flywheel?? its in the bellhousing on every vehicle made. so ya have to pull the motor or pull/slide the tranny back
