Loss of power in 1984 bronco2 2.8 5sp trans
I bought the truck last October it had the stock tires which were i believe 205 70 15.I drove it home fine did a bunch of work to it.Also put 31 inch tires on and i just got it plated about a month ago and when i drove it it won't go faster than 40-45mph unless of course going downhill i didn't fix anything to the motor or drivetrain besides a tune up plugs,wires,oilchange,and air filter other than that wheel bearings,tie rods,new cat,and brakes.So any info i can get will be great.Thanks
1984 Bronco II
Re: Loss of power in 1984 bronco2 2.8 5sp trans
put the stock tiers back on
they need more info, does it surge, idle rough, hesitate,was it cold outside? mine did that found out ice was on the carb.
it gets that cold in TXbroncofan wrote: found out ice was on the carb.
Yes, Jan,Feb really gets cold here. Central TX gets a mix of it all, but mostly ice storms if anything. Esp that last blast avg temp was like 15 for 2 weeks. Just now starting to warm up some
