5.0 Install
Re: 5.0 Install
I have those wire colors on my ignition module, just not in the same order. The few that go to the dizzy also have stripes.
Re: 5.0 Install
Here are the pics of my wire colors. They don't go in order with the one in the wiring diagram but the colors are all there. So I'm just going to wire it up like the diagram shows.
Re: 5.0 Install
So I was going to switch the gears on my distributor. Got the pins out, pressed em off. They are different diameters, and the teeth are cut opposite. I'm a little frustrated, I have a huge list for parts now at the junkyard.
Re: 5.0 Install
It was an 84 f150. I ran the vin through a decoder and it said it was a 300 I-6 orginally. The intake manifold bolted right up. Valve covers too. I don't know. I'll be more careful when I'm there Friday. I'm not leaving until I have everything I need.
Re: 5.0 Install
It was an 8 cylinder block. Did they put the wrong distributor in? Does that mean I need a different ignition and coil?
Re: 5.0 Install
you need to post some pics. did you unbolt the dist. and pull it out on the V8 block
Re: 5.0 Install
Yes I did unbolt it from the block. What do you need pics of? I will
get them tomorrow afternoon.
Re: 5.0 Install
ive never seen a 302 dist. with the gear cut different. they all go the same way as far as iv seen
Re: 5.0 Install
I'll get pics of them side by side. It's got to be the wrong dist. or something then. I don't know if I should look for a different ignition now too? What do you think?
Re: 5.0 Install
Huh?Ranger Dave wrote:i dont it runnin
Re: 5.0 Install
Haha. Thanks for staying behind me through this. I'm getting different ignition parts next Friday. We'll see what happens then. I'll have wiring questions then for sure. Then it should be ready.
