Electrical Issue
95mustangdave81
Electrical Issue
A month ago I put a newer engine in my '87 Bronco II automatic 4X4. It has 60,000 miles on it, it has all new sensors, valve cover gaskets, oil pan gasket, water pump, fuel pumps, etc. It has fuel but no spark. I have replaced the ignition coil, plugs, wires, cap/rotor, ignition module and stator. Still nothing. I have tried every test that Chilton's and All Data suggests, and have taken it to two shops and they can't figure it out. I don't know what else to do/check. There just doesn't seem to have anything coming out of the ignition module/distributor. Does anyone have any suggestions? ( When installing the knock sensor the threaded part broke off in the block so I have to drill it out and replace it, would that cause a problem?) Thanks!
