1990 bronco II drive line help
outlawnunn
Post by outlawnunn »
I have a 1990 bronco II the drive line broke can i get a real drive line off an older bII
thanks wayne
1990 bII xlt 3inch jd lift, 30x9.5's
chucknti
Re: 1990 bronco II drive line help
Post by chucknti »
best thing to do is measure from flange to flange on your axle and t case, and get one made for around 250 to 300 bucks
outlawnunn wrote:I have a 1990 bronco II the drive line broke can i get a real drive line off an older bII
thanks wayne
yes
WaPaul
Post by WaPaul »
for less than $100 go to your local you pull it and get one off an explorer. They take the same 12mm 12 point, take both flanges and driveline. Cut down the driveline, weld on the end for the U joint, then take it to the local driveline shop and have them balcance it. You can drive it without balancing it if does not shake when you get up to speed, but its almost if must to have it balanced.
