PLEASE HELP!?!?!?!?!?!
Re: PLEASE HELP!?!?!?!?!?!
ok so i got the module out, it wasnt to hard and it turns out it was held in with 5.5mm bolts, so now i am wondering if there is anyway to see if its faulty or not using a volt meter or something like that
86 bronco II
2.9l v6 5speed
5.5" superlift with 33 12.5s super swampers
2.9l v6 5speed
i just got an 89 bronco II it has the same problem as 86 bronco II no power to injectors. previous owner changed computer pickup coil and control module. still no power to injecters runs on starting fluid feul pumps only run when hot wired also changed fuel pump relay
so have you got it running yet bill?
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
no just got it haven't had time to work on it yet. lf l find the problem i will let you know
got the module tested and it passed multiple times
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
If it starts on starter fluid shouldn't the module be good? Have you pulled an injector to see if it's spraying right? Sorry if you already went over this, I'm just trying to start at square one in case we missed something simple. You have rotation, ignition,compression, it seems getting fuel to the fuel injectors is the issue ( not trying to state the obvious here just recapping) just one more thing, how old is the gas in the tank?
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
the injectors aren't opening, no pulse. it has fuel pressure at the rail.
In the schematic I see a couple in-line fuses, have these been checked, it sounds like you've had a few shorts which will cause these to blow.
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
there isnt any pressure at the rail unless i hotwire the pumps
86 bronco II
2.9l v6 5speed
2.9l v6 5speed
got that bronco home today. it is an 88 there are 3 wires to the negitive post one big one to motor block. one small one to header panel. the other one going towand the fender has a plug in it. it is black with a green stripe leaving the plug.just like ranger dave said. on mine the plug was bad. i rewired it and it statrd right up. it is the ground wire for fuel injection
thanks for the good info Ranger Dave
