installing oil pressure gauge
Syko
Post by Syko »
87 b2 2.9. where do hook it up? i think the gauge is either mechanical or electrical not to sure but it did come with the tube. which is better?.. i dont know if im really blind or looking in the wrong places i cant find anything in the manual.. any ideas?? and my oil pressure on the stock gauge points right at the N of normal is that to high? Thanks!
I like the copper tubs if you want my opinion, the plastic ones break too easy. you need to find the oil pressure sending unit. usualy on the side of the block. a trick I used to do when I was still learning was to go to the parts house and ask to see the part. then go out and look. most of the time they would just come out and show you if you told them what you are doing.
