where can I find a 2 or 3 inch suspension lift?
I can't find any cheap lift kits for my 1990 bronco II. I don't want a real high end one just one big enough to fit maybe 31's or 33's on it. I'm also having trouble with my electronic 4x4 not going in 4 just 2 and the light comes on though. if anyone could help me I'd really appreciate it, thanks.
You might have to check the soliniod that goes to your tansfercase. As for the lift you can fit 31's stock with the right wheel offset. If you want there is a company on ebay that sells a two inch lift.
greenmachine89 wrote:You might have to check the soliniod that goes to your tansfercase. As for the lift you can fit 31's stock with the right wheel offset. If you want there is a company on ebay that sells a two inch lift.
might be a stupid question but where would that solinoid be and what does the wheel offset do to fit bigger tires on?
