Mig Gas
Mig Gas
Postby Nobody » Fri Dec 28, 2007 3:32 pm
I think I'm going to buy a gas bottle for me 110 wire feed welder. What % argon should I get, and what size bottle would you recommend? Should I stick with .035 for exhaust work?(16 guage)
Postby EBSTEVE » Fri Dec 28, 2007 10:18 pm
I like 75/25 gas and you can stay with .o35 but I would go smaller if I was to buy more say .o23 but I did my exhaust with .o35.
HTH
Postby tekatlarge » Sat Dec 29, 2007 5:09 pm
I am going to let out one of my secrets for welding thin sheet steel like floors fenders etc...
Check out this link for this stuff!
New JW Harris "20-Gauge" Cored Welding Wire-.030"-10lb
I know this isn't mig but sometimes simple is better.
This is a cored wire that will give you impressive results
http://stores.channeladvisor.com/weldsa ... k=72887138
Kent,Worshington
Postby ranger5.0 » Sun Dec 30, 2007 7:42 pm
I found that running .023 made hotter nicer welds with longer duty cycles over the .035 and/or .030.
deputyfestus
Re: Mig Gas
Postby deputyfestus » Sat Jun 14, 2014 12:55 am
I have a nice 12 yr old Century 110 v gassless. I don't have power to my little workshop so I run a cord from the back of the house where the hot tub used to be. Its a 12 guage HD cord but is 50' long. Will a shorter cord produce less voltage drop and therefore better penetration on my welds? Tried.030 and .035. Both about the same. Thanks.
Re: Mig Gas
Postby tekatlarge » Wed Jun 18, 2014 7:44 pm
I think it may be a bit long for optimum operation. I run my millermatic 185 some times on a 25 foot !0Ga "Extension cord". Of course that is 220v. it doesn't run as well as plugged into its plug below the main Panel.
I think 100ft is excessive distance to try and pull any amperage. A 110 welder needs every amp it can get. If it gets all the amps it needs it's happy and welds look good. If the voltage drops on the input the machine will be real hard to get a arc to start and could cause sticking and blowing.
One other quick tip. If your wire has been outside like in a cold garage for any time, The wire will build a surface rust that causes problems because the feed roller assembly which usually makes the electrical connection to the feed wire. The rust will cause hi resistance and will be hard to keep a arc struck because of inconsistency of the current.
When I am going to do some tacking or welding and I haven't used the welder in a while, I sometimes take a piece of scotch brite and roll about 10 feet or so of wire. I roll the wire back up holding it between the scotch brite pads and that way I start out with good connections right out the door.
Kent,Worshington
