Axle Upgrade
djadjective
Axle Upgrade
Post by djadjective »
In the spring Im going to replace my leaf springs on my 88 Bronco II and a friend of mine has a Ford 8.8 sitting around he doesnt need. So my question is what would need to be customized with that axle swap; U-bolts, Driveshaft, shock mounts? Also what would be the best choice one out of a ranger or early exploder? The rear driveshaft in there now is a non-CV dana built one, and Im not sure if there would be enough play in the sleeve to match up to the larger 8.8.
whats the 8.8 out of? a exploeer would be the best choice. Dont know to much whats needed to do the swap. But ifs its out of a full size its going to be really wide and run a different lug pattern with a large 5 instead of the small five you have now.
djadjective
He told me it was out of a late 80's ranger.
onewyr
Post by onewyr »
don't use it if it is out of a ranger if I am not mistaaken the ranger axles are narrower than the b2 axles.
use a explorer axle they have 31 spline shafts and they are wider than the b2 axles
ranger ones are also off centered too
djadjective
Ill measure it and if its not right, I'll just hit up a junk yard and find an exploder. Thanks for you help.
