Can I disconnect my sway bars?
Forest Falls Crawler
I have an 86 Bronco II with a 6" Skyjacker lift on it and a 3" body lift with 36" super swampers. In the future I plan to convert the front axle to a straight axle set up. For now I am broke and will be using the stock front suspension set up. I want to know if I can disconnect the front sway bars for more travel. I have not been able to find a quick disconnect set up for the Bronco II, so I am guessing the answer is no, but I would really like to know for sure.
I have EVERYTHING you need to do a sas, dana 44 front w/disc brakes, new calipers and rotors/bearing, 9" rear with lincoln lock,it was pulled from a running driving BroncoII to facilitate the install of rockwells. All is there, including the trac bar and frame mount for it. All located in Ky.
92 XJ-wifes toy
92 XJ-wifes toy
Sway Bars
I have a 6 inch lift with 33's and no front or rear sway bars and I drive mine daily little bit of sway when turning hard or jerking the steering wheel back and forth but other than that I like it never had a coil spring come out or anything yet.
88 Bronco Duece 6 inch lift 33' BFG M/T's,8.8 rear
http://www.cardomain.com/ride/2931432/1
Bronco Ollie
