Help pulling springs
nickb
Post by nickb »
OK this might be a stupid question. I'm going to a U-pull it junk yard for explorer spings, I can't take a torch or a generator in the yard. So what would be the easiest way to get all the springs off and what size wrenchs would I need? Thanks for any help on the easiest way to get these off
84_4x4
Post by 84_4x4 »
not sure on wrench sizes but i would say pb blaster and a bfh (big flippin hammer) maybe some propane torch if thats allowed to put some heat to em if the bolts are stuck
If they will let you take a sawsall cordless take it and cut the spring hangers off. Cut the u-bolts as well for a quik pull. If not take a socket set and a can of PB blast. Still should take too long. Maybe a cheater bar about 3' in case you need the leverage. Good luck.
bower100
Post by bower100 »
nickb,
This might be too late to help you, but in case not here goes.
Just two days ago ,I wastrying to get the springs off a 1992 Sport Explorer thats going to the junkyard.
The u-bolt nuts on both the Explorer and the BII are 18mm...deep socket needed for the Explorer.
The spring eyebolts and nuts are 21m.
dave
