My Wee Beasty
COWBOY6
My Wee Beasty
Postby COWBOY6 » Wed May 04, 2005 10:33 pm
This is the beginnign stage of the Bronco II Build
This is the day I brought it home. $500
Here is a new pict after the doors were cut, the body has been lifted 3 inches.
[/img]http://memimage.cardomain.net/member_images/1/web/829000-829999/829357_8_full.jpg[/img]
It only hurts when the bone starts to show, so walk it off.
http://members.cardomain.com/cowboy6
COWBOY6
New convertible added to the list
Postby COWBOY6 » Sat May 14, 2005 10:40 am
Here it is right after the roof came off.
tell me what you think.
I am still needing to cut the top of the door frame off. close the pillars, finish the windshield, and cage the whole rig. ALso need to add a support brace tot he rear quarter panel right behind the door to stiffen the wall.
Thanks for the look and the opinion
Postby ranger5.0 » Sat May 14, 2005 9:16 pm
You will need to support the windshield frame for sure. If cut the doors you should remove the door glass since there will be nothing to support those either. Looks like you will need a lift with those tires unless you cut the fenders too. Nice clean start though. Good luck!!
Postby DBrown » Sun May 15, 2005 3:40 pm
definatly keep the pics comming, that was the next idea I had for mine. you will need a roll bar now, that is the only thing holding me back from getting out the swazaw again.
COWBOY6
Postby COWBOY6 » Sun Aug 14, 2005 1:54 pm
Well, I have most of the build done. I have the B2 caged, half doors, painted and bumpers, rear swing out built.
next is the soft top to make...
Here are a few picts
Have some more ideas, but maybe pass to some other brave builder with a saw and fresh metal
crazy4ink
Postby crazy4ink » Sun Aug 21, 2005 12:22 am
I like the look man! Could you post a close up of the cage meeting the windshield frame? Are they tyed together or does the cage go down just inside of it to the floor? I'm really wanting to chop my top off, but trying to decide between full chop or back-half chop.
COWBOY6
Postby COWBOY6 » Fri Sep 16, 2005 11:02 am
The cage goes all the way tot he floor, and I am tying it to the frame
Send me an emso I can send attachments.
janshan3@earthlink.net
that is open to all that want picts of different stuff fromt he build.
I have picts of the doors, the cage the tire carrier, and soon the top.
Thanks,
James
Return to “Member Rides”
