finally tested out 'newfound' flex.
BDEUCE
Post by BDEUCE » Tue Aug 21, 2007 10:06 pm
well, i did the sploder spring swap a couple of weeks ago, and i also removed my rear swaybar. i didn't notice any on road handling change without the swaybar. i didn't get a chance to go into the woods until today, and holy crap does she flex! i'm half tempted to remove the front one now!!!
pics...
i was actually at the dump, and decided to drive up on an old excavator tire.
now look at the front, this picture is making me think the front swaybar has got to go, to give my d35 a chance to stretch it's legs (arms?)
i went to a local lake, alot of sand, there was this hill with pretty big ruts on it. last year, i tried to drive up it, but i lost contact with a wheel, and stopped going forward. today, i drove right up it. i had to go back up again, and stop on some of the ruts to show you this:
tis a thing of beauty.
so what do you guys think, remove the front? will i hate it on-road? this is still a dd until i can afford a smart car
:finger:
PHROX
Post by PHROX » Thu Aug 23, 2007 3:57 pm
I vote remove it.
Post by Phillippi » Thu Aug 23, 2007 8:38 pm
You could remove it, but it will effect the onroad handling a bunch. But you will get some more flex but not as much as the front. TTB isnt designed to flex like a solid axel.
PHROX
Post by PHROX » Fri Aug 24, 2007 5:37 pm
Here is mine without a sway bar....... wow! I actualy have front articulation!?! its been a while
BDEUCE
Post by BDEUCE » Fri Nov 30, 2007 10:47 am
phrox, is there relevance to this pic? i don't have a solid axle in the front.
Post by Rockcrawler » Fri Nov 30, 2007 1:25 pm
if you do pull the sway bar off the front make sure to bolt the coils in up top i had one pull out.
Bronco Ollie
Post by Bronco Ollie » Fri Nov 30, 2007 9:22 pm
deuce take it off truck looks good
PHROX
Post by PHROX » Sat Dec 01, 2007 8:30 am
no, no relivance. just showing off. but seriously take it off.
TJDukit82
Re: finally tested out 'newfound' flex.
Post by TJDukit82 » Tue May 06, 2008 12:14 pm
Make some quick disconnects for your swaybar that way you don't have to worry about your road handling so much.
'89 Bronco II
'03 GMC Sierra Z71
88budget4X4
Re:
Post by 88budget4X4 » Wed Sep 03, 2008 4:10 pm
PHROX wrote:Here is mine without a sway bar....... wow! I actualy have front articulation!?! its been a while
i take it the front sway bars still on on this thing? tires are better when touching the ground lol...
