wiring harness
skyhigh85
wiring harness
Post by skyhigh85 » Sun Oct 24, 2004 12:36 pm
I need to know which wires to conn. to brain box from ing :cool:
TNMAN
Post by TNMAN » Sun Oct 24, 2004 5:05 pm
Are you using the stock ignition? When I put the new Duraspark on my V8 I had to just trying every wire till I got it figured out. If you are using this type(Duraspark) ign......the start circuit has to have a hot wire all thru the start cycle.Some of Fords switches did not have a hot wire when the switch was turned to the start position. I hope this helps some.
skyhigh85
Post by skyhigh85 » Mon Oct 25, 2004 11:02 am
TNMAN wrote:Are you using the stock ignition? When I put the new Duraspark on my V8 I had to just trying every wire till I got it figured out. If you are using this type(Duraspark) ign......the start circuit has to have a hot wire all thru the start cycle.Some of Fords switches did not have a hot wire when the switch was turned to the start position. I hope this h
helps some.
thanks for your help.
one more ?
did u use factory comp. or ford brain box???
Post by DBrown » Mon Oct 25, 2004 12:21 pm
if you are using the factory brain box the red wire comming out of the brain box has to be hot when the ignition is on. the 4 prog clip just plugs into the motor part of the harness. and the wite wire on the 2 prog clip goes to the starter wire. but you can leave it unhooked if you want it makes no difference. your motor will run with this set up as long as you complete the rest of the harness.
skyhigh85
Post by skyhigh85 » Mon Oct 25, 2004 4:37 pm
DBrown wrote:if you are using the factory brain box the red wire comming out of the brain box has to be hot when the ignition is on. the 4 prog clip just plugs into the motor part of the harness. and the wite wire on the 2 prog clip goes to the starter wire. but you can leave it unhooked if you want it makes no difference. your motor will run with this set up as long as you complete the rest of the harness.
thanks Iwill try this my next day off and send reply.
TNMAN
Post by TNMAN » Mon Oct 25, 2004 6:27 pm
I use the aftermarket Ford-type box.....BLUE.
Post by DBrown » Tue Oct 26, 2004 6:56 am
yeah, I have the one with the blue clip on my 351M also. I think that box will run any ignition.
