What did you do with your Bronco II today?
offroadohio
Postby offroadohio » Thu Feb 09, 2017 12:47 pm
This is an old build. Springs were flat. So I put explorer leafs and removed the lift blocks and put a stock shackle back on.
Sucked the front down with the winch and added a center limit strap.
Hoping this will stable it up a good bit.
Here is a before...
offroadohio
Postby offroadohio » Mon Feb 13, 2017 1:31 am
offroadohio
Postby offroadohio » Mon Mar 06, 2017 5:44 am
Postby Phillippi » Tue Mar 07, 2017 6:01 pm
My bronco (my first vehicle I ever purchased), moved to a new home. It was a very sad day.
Goodbye buddy. You have served me well your entire life...
offroadohio
Postby offroadohio » Mon Mar 20, 2017 3:25 pm
offroadohio
Postby offroadohio » Thu Mar 23, 2017 6:45 am
Poser
offroadohio
Postby offroadohio » Mon Apr 10, 2017 9:09 am
Pesky 9 inchesImage
Mer925
Postby Mer925 » Sat Apr 15, 2017 9:00 am
@ohio, that awkward moment you do a lift in your garage and find out the hard way that now it wont clear you garage door ha.
Sent from my SM-G920V using Tapatalk
Lance Skene
Postby Lance Skene » Fri Nov 17, 2017 8:01 am
My first B2 along with a couple Ford garden tractors after a day on snow duty...
'80 Bronco 351M
'85 BII 2.8/Duraspark
'89 F150 302 Supercab
Lance Skene
Postby Lance Skene » Sat Dec 30, 2017 8:52 pm
Cold as XXXX here but the snow has to be moved...
'80 Bronco 351M
offroadohio
Postby offroadohio » Tue Feb 06, 2018 3:57 pm
Tire swapImageImage
offroadohio
Postby offroadohio » Sun Mar 11, 2018 8:06 am
Built some custom coil mountsImageImage
offroadohio
Postby offroadohio » Wed May 02, 2018 9:06 am
http://www.broncoiicorral.com/donnie-ch ... -bronco-ii
JohnnySal
Postby JohnnySal » Thu May 17, 2018 9:06 am
Looks really good, Offroadohio. Is the design of those coil mounts your own as well?
offroadohio
Postby offroadohio » Sat May 19, 2018 3:40 pm
Yes they are my design.
Just went on a 950 mile trip and they worked great. Image
Return to “Chit Chat”
