Short ram intake
Reinforcements
Short ram intake
Post by Reinforcements » Wed Sep 14, 2005 11:01 pm
Is there anyone out there that can tell me how to get a short ram intake for my b2? Is it a custom job or is there a place you can buy them?
Risky Bidness
Post by Risky Bidness » Thu Sep 22, 2005 7:20 pm
ive only ever seen custom ones, ive looked for a kit that you can buy but never found one, but its really simple to make one yourself, i myslef havent made one but have seen it done
'88 BII
Post by DBrown » Fri Sep 23, 2005 7:51 am
are you talking about one that just comes off the motor and and has a cone filter?
B2JAY
ram air intake
Post by B2JAY » Mon Sep 26, 2005 9:54 am
I heard a while back, you could use the one from certain year dodge neons. 95 I think was the year but I'm not sure.
sailor45
Post by sailor45 » Wed Sep 28, 2005 10:56 am
easy fix go to the junk yard find the style intake you want from another car. i used a piece of climate ducting to make mine then i took that off and made a home made snorkel out of pvc pipe
i used to have a 87 wrangler but i broke it everywhere i went so i got a 89 b2 and i can't stop this thing.
Reinforcements
Post by Reinforcements » Mon Oct 24, 2005 4:10 pm
so could I just remove the top portion of the air filter box and just bolt on a cone filter to the end of the existing intake hose, or is there more to it than that?
Post by ranger5.0 » Mon Oct 24, 2005 6:43 pm
The probelm with the cone filter is that it will be more susceptable to sucking up water.If you are going to all the trouble to reroute your intake you might as well build a snorkel. BTW a replacement K&N filter works just fine.
Post by DBrown » Tue Oct 25, 2005 5:01 am
you will get more performance out of a stock replacement K&N then a cone under the hood.
madmaxb2
Post by madmaxb2 » Tue Oct 25, 2005 5:44 pm
snorkel it. :idea:
Risky Bidness
Post by Risky Bidness » Fri Dec 23, 2005 5:31 pm
get a cold air for a 95 neon, and do a 58mm throttle body swap, more power than the K&N :)
'88 BII
