Motor surges,hunts for power....HELP
Hi guys my 89 Bronco II has the stock 2.8L with 90,000 miles on it but it is now starting to surge or hunt for power that isnt there or in some cases is there but on and off...is this a sensor or loose wiring? i have changed the plugs but nothing else PLEASE FILL ME IN
go to autozone and have them run the codes for you they will do it for free. that will point you in the right direction.
it could be fuel related or it could be ignition.... i would check the fuel pressure and make sure it's not the pump or filter.... it seems pressure regulators are prone to failure also... if fuel system checks out ok, i would give it a complete tuneup including cap and rotor.... is the check engine light coming on?
Give a call for a special price on brake or exhaust work Exhaust Tech 253-333-7200
02 sensors also. I think the replacement interval is about 90,000 miles.
85 Longbed 4x4
85 Longbed 4x4
it sounds to me like you have a bad coolent temp sensor, but like I said untill you pull codes you will have no direction as to what you are replacing.
