ok, I replaced the TFI module, tryed a diferent coil and still i have no spark....
HOWEVER... I DO have spark when I disconnect a Little fuse like thing on the wires goin to the TFI module but it won't start... but when i put it back in i have no spark.
are you getting anything at the coil (spark ,volts)??? if not check to see if there is voltage at the coil. make sure your coil is not grounded meaning there are only 2 wires going to it.
are you getting fuel? you should be able to fire it up with the the link disconnected. how are the plug's looking? do they have fuel on them when you try to start it?
i'm assuming the fuse thingy you are talking about is the whatchamacallit that you take out to time the motor all it does is disables the timing advance so i would go from there with your search.maybe this will give some of the other guys an idea for you. I just know enough to get myself in trouble and go buy more parts and tools
