89 bronco ii
89 bronco ii
I got an 89 bronco ii a couple months ago. It’s seems to run ok when cold but looses power when warm. If I turn the ignition off and start it again it seems to run ok for a mile or two then looses power again. Anybody have any ideas what could cause this problem?????
Re: 89 bronco ii
Fuel pump do a search here
Re: 89 bronco ii
Fuel pump is a common failure item but remember a BII has 2 fuel pumps. 1 low pressure pump near the tank and a high pressure pump on the frame rail drivers side near the front of the door. Also don't forget the Fuel filter too.
Kent,Worshington
Kent,Worshington
