85 B2 tranny A4ld
Tomin southernIL
85 B2 tranny A4ld
Post by Tomin southernIL »
shifts hard into reverse, vibrates in all gears, won't shift into overdrive. was 2/3 quart low fluid added required amount old fluid looks and smells ok
PlumCrazyChris
Re: 85 B2 tranny A4ld
Post by PlumCrazyChris »
Did you have a question? Did the additional fluid fix your problem?
Tomin southernIL
additional fluid will fix hard shift and no shift problem along with new filter. Two bearing caps on rear universal cracked and missing pieces, new universal's will fix vibrating, amazing how looking at a problem from a bird's I view solves the problem.
