Tach gauge loves to dance ??
cdmiller
Postby cdmiller » Sun Aug 30, 2015 6:24 pm
The rpm gauge on my 89 B2 jumps all over the place.While sitting in the driveway,in park,just idleing the rpms go up to 4 or more.Sometimes while driving it will settle down to normal,but not often.The speedo jumps a little too,but not as much.
Any help is appreciated.
Re: Tach gauge loves to dance ??
Postby tekatlarge » Mon Aug 31, 2015 6:33 pm
You might check the instrument panel voltage regulator. They are usually mounted to the back of the instrument Panel. It supplies a solid steady reference voltage for the instruments. When the instruments go wonky look at this item first! BTW: Wonky really is a word. My 35 year old daughter swears it is.
Kent,Worshington
Return to “Bronco Tech”
