Wheel and tire size
BroncoBruce86
Wheel and tire size
Postby BroncoBruce86 » Sun Feb 22, 2015 4:40 pm
New to the forum, have a 1986 B11 all stock even wheels. Wanted to install a set of 15x7 stock wheels from an 88 and wanted to know
if a 235/75/15 tire would give any trouble.
Thanks
rayrayd
Re: Wheel and tire size
Postby rayrayd » Sun Feb 22, 2015 7:53 pm
Welcome Bronco Bruce! I have a 84 4x4 with no lift - I'm running 31 10.50 R15 on the factory rims. If I turn real sharp while hitting a bump the front rub a bit. You won't have a problem with the 235's
Lance Skene
Postby Lance Skene » Mon Feb 23, 2015 8:44 am
235/75s are a nice fit, thats what I have on some '94 Ranger rims under my '85 B2. Might want some extra wide mud flaps tho as they will throw more mud up onto the truck.
'80 Bronco 351M
'85 BII 2.8/Duraspark
'89 F150 302 Supercab
BroncoBruce86
Postby BroncoBruce86 » Mon Feb 23, 2015 1:24 pm
Then that's what I'm going with. B11 in transmission shop now hope to have it back Friday.
Thanks for the info will let you all know the outcome and will try and post some pics soon.
BroncoBruce86
Postby tekatlarge » Tue Feb 24, 2015 1:45 pm
Hey BroncoBruce86,
Is that an A4LD automatic With OD.
Let me know what the shop did and how it works.. I am curious..
TNX :cool:
Kent,Worshington
BroncoBruce86
Postby BroncoBruce86 » Wed Feb 25, 2015 3:39 am
Yes it is an AOD and I will let you know. Suppose to be ready Fri. told them to do a total rebuild and the estimate
was $1200.00 to $1700.00 so we will see.
