Need right hand shaft assy!!!! Help!!!!!
rayrayd
Postby rayrayd » Tue Feb 10, 2015 6:38 pm
1984 B2 4x4 with Dana Spicer model 28 front axle. I need the right front outer cv axle - lost seal and bearing which trashed the right hand shaft assembly and can somebody tell me for sure that the outer shaft will slide out of the inner shaft (please tell me it will!) and if it does the best way to separate it without to much beating and banging and damaging the inner shaft the part number I need is a Dana Spicer 71702-1x cheapest I can find is $229 + shipping Help Help
rayrayd
Re: Need right hand shaft assy!!!! Help!!!!!
Postby rayrayd » Tue Feb 10, 2015 7:16 pm
the outer section of the right hand shaft assembly is part # SPI-40394 I can't find this part at all
