D35 LS
swampfoxforeman
D35 LS
Postby swampfoxforeman » Wed Nov 05, 2014 4:14 pm
What do I need to do to put a LSD in the D35 on my Bronco II?
Re: D35 LS
Postby tekatlarge » Thu Nov 06, 2014 8:03 pm
Basically you just pull the axles, drop the dif cover, and remove the carrier, Swap your ring gear into the lsd assembly, Re install and reset gear backlash. Then put the axles in, cover on, and add LS lube. Then go Tear it up!!!! :cool:
Kent,Worshington
swampfoxforeman
Re: D35 LS
Postby swampfoxforeman » Fri Nov 07, 2014 4:39 pm
Ok any idea of a place to get a LSD for it? I have heard something with Jeep LSD.
Re: D35 LS
Postby tekatlarge » Sat Nov 08, 2014 10:13 am
Look in your local Pick A Part auto boneyard. Look for Explorers with the dana 35 and check the numbers on the door for LSD. They put a lot of LSD's in explorers. :cool:
Kent,Worshington
