Spring Problems! Please help
Lifted_B2
Postby Lifted_B2 » Thu Aug 21, 2014 5:41 pm
i just lifted my B2 four inches, and now that it is done, the front wheels sit like this \-o-/ they are five degrees out. the springs look as if they want to pop out and they do not seat very well, so i believe they are to long and stiff. can someone with a four inch lift please measure their springs (under load is ok) and possibly post a pic so i can see how they fit. thank you.
Mud Addict
Re: Spring Problems! Please help
Postby Mud Addict » Mon Aug 25, 2014 10:43 pm
Does your lift brackets have two sets of holes? If so try moving to lower hole. Where you at in Washington?
2813josh
Postby 2813josh » Thu Nov 06, 2014 6:46 pm
Did the kit you used come with drop brackets for the axle? Anything over 2 inches of lift they are a must. Also,you'll need camber bushings.
I have 5" on mine with 3 deg camber bushings,if I remember correctly.
2813josh
Postby 2813josh » Thu Nov 06, 2014 6:48 pm
2813josh
Postby 2813josh » Thu Nov 06, 2014 6:50 pm
Only pics I have at the moment. First one shows the bracket you need. There are actually 2.
The second is the camber bushing..the big castle but deal in front of the spring.
Return to “Bronco Tech”
Users browsing this forum: istellabot [Bot] and 1 guest
