Spring Problems! Please help
Lifted_B2
Postby Lifted_B2 » Thu Aug 21, 2014 5:41 pm
i just lifted my B2 four inches, and now that it is done, the front wheels sit like this \-o-/ they are five degrees out. the springs look as if they want to pop out and they do not seat very well, so i believe they are to long and stiff. can someone with a four inch lift please measure their springs (under load is ok) and possibly post a pic so i can see how they fit. thank you.
Mud Addict
Re: Spring Problems! Please help
Postby Mud Addict » Mon Aug 25, 2014 10:43 pm
Does your lift brackets have two sets of holes? If so try moving to lower hole. Where you at in Washington?
2813josh
Postby 2813josh » Thu Nov 06, 2014 6:46 pm
Did the kit you used come with drop brackets for the axle? Anything over 2 inches of lift they are a must. Also,you'll need camber bushings.
I have 5" on mine with 3 deg camber bushings,if I remember correctly.
2813josh
Postby 2813josh » Thu Nov 06, 2014 6:48 pm
2813josh
Postby 2813josh » Thu Nov 06, 2014 6:50 pm
Only pics I have at the moment. First one shows the bracket you need. There are actually 2.
The second is the camber bushing..the big castle but deal in front of the spring.
