86 BII Eddie Bauer with bad electrical issue
wilsonsuarez
Re: 86 BII Eddie Bauer with bad electrical issue
Postby wilsonsuarez » Thu Dec 26, 2013 12:31 pm
hey man, im tired of fixing almost countless years of shotty elec patch work and having random things fail every time i hit a puddle! if i can swap the eng harnes out and be sure its fixed for good, im excited!! :D
wilsonsuarez
Postby wilsonsuarez » Fri Jan 03, 2014 7:59 am
@ phillipi, did you ever get around to seeing if you had that b2 harness??
dgl6y6
Postby dgl6y6 » Fri Jan 03, 2014 10:41 am
You might try this place.
http://www.wireharnessrepair.com/Home_Page.html
They have a picture of what looks like a b2-era ford wiring harness.
Postby Phillippi » Fri Jan 03, 2014 10:46 am
Oh crap I'm sorry I've been crazy busy at work. Today I have off, and I will rummage through my stock of stuff and check.
Postby Phillippi » Sat Jan 04, 2014 1:02 pm
So I went out and found the harness I was thinking of, but now I cannot remember if this is the 2.9L harness or a 5.0 harness. Any tell tale signs to figure it out easily?
Postby Phillippi » Wed Jan 08, 2014 6:52 pm
Anyone??
wilsonsuarez
Postby wilsonsuarez » Wed Jan 08, 2014 7:19 pm
I have been looking and can't seem to find a side by side comparison, just peoples builds and swaps but they don't show the differences in harnesses. I have also posted on other sites as well but I can't get a reply. This weekend, weather permitting, I will go out and make a list of my 2.9l connectors on the main harness and will post to hopefully have something to compare to. Hopefully someone can shed some light on this soon.
Postby tekatlarge » Thu Jan 09, 2014 7:08 pm
Hey Phillippi,
If you know the year of the rig the harness was removed from just grab your Haynes and check colors to various connectors. If you don't have a Haynes stop by my site and look it up in the tech library. there is a difference between the two!
Kent,Worshington
Return to “Bronco Tech”
