ELECTRICAL PROBLEM
Posted: Sun Jun 30, 2013 10:57 am
by zamnep
I HAVE ELECTRICAL PROBLEM. THE 15 AMP FUSE THAT CONTROLS THE TURN SIGNALS,TURN SIGNAL INDICATOR, REAR WINDOW DEFROST & BACK-UP LAMPS, BLOWS WHEN I TURN THE IGNITION SWITCH ALL THE WAY ON (JUST BEFORE STARTING). I HAVE LOOKED IN THE OBVIOUS PLACES EVEN PULLED THE STEERING WHEEL TO ACCESS ADDITIONAL WIRING. REMOVED THE REAR DEFROSTER SWITCH AS WELL AS THE TURN SIGNAL ASSEMBLY. STILL BLOWS THE FUSE. H E L P H E L P H E L P !!!
ZAMNEP
Re: ELECTRICAL PROBLEM
Posted: Fri Oct 11, 2013 5:06 pm
by Yeti
You may have a water leak.
I just pulled all my interior and I found water leaks in front and back. Pull your kick panel next to the fuse box and check for rain or rust. Broncos are notorious for leaks. I have all my interior out. The back of my computer was starting to rust.
Posted: Sat Oct 12, 2013 8:59 am
by drofman
unplug your muti-function swt and try it then. if it doesn't blow the fuse, it's the muti-function swt.
Posted: Sat Oct 12, 2013 9:03 am
by drofman
wow i just saw how old this is probaly fixed it already
