fuel issue? piston issue? electrical issue?
Posted: Sat Jun 15, 2013 11:25 am
1990 Bronco 2 2.9L V6
OK, Here is the symptoms my truck starts right up and idle's at 1200 RPM and idle's just fine with no fluctuation. While it is still in Park I press the gas pedal and it rev's just fine I am able to hit 4k+ RPM.
It is the same way in neutral runs good sounds strong.
BUT when I put it in either Reverse or Drive/OverDrive, I press the gas and it acts like it wants to stall out. But it doesn't stall out, it just stops accelerating just rumbles really low. Then soon as I let go of the gas it goes back to idling fine. I can drive the truck around the neighborhood while just barely giving it gas not to exceed 2k RPM and 25 MPH it seems.
I was told to try replace/repair a few things so I did.
all things are put on correctly :))
Fuel Pump
Fuel Filter
Fuel Pressure Regulator
Spark Plugs
Ignition Coil
Throttle Air Bypass Valve
O2 Sensor
Catalytic Converter
Muffler
Distributor Cap
Cap Ignition Rotor
Fuel Pump
Fuel Filter
Spark Plugs
Ignition Coil
O2 Sensor
Catalytic Converter
Muffler
Distributor Cap
Cap Ignition Rotor
