oil pressure switch removal on 1987 2.9 ltr. bronco 2
droblowin420
Postby droblowin420 » Fri May 31, 2013 4:08 pm
do you have to remove the motor mount to remove the oil pressure switch, or getting the oil pressure switch socket would fit in between the mount and oil pressure switch?
drofman
Re: oil pressure switch removal on 1987 2.9 ltr. bronco 2
Postby drofman » Sat Jun 01, 2013 4:15 pm
I have done it with a swt. socket but it's tight. Might have to go at it off center. Good luck.
Users browsing this forum: istellabot [Bot] and 1 guest
