water leak
Dano
water leak
Postby Dano » Sat Nov 17, 2012 12:10 pm
I have a 1990 b2 I have noticed that i am leaking water / antifreeze under the passenger side fender well. Thought it was a cracked engine but looked and there is a small rubber hoes where the fluid is coming from what is it and how do i fix it
drofman
Re: water leak
Postby drofman » Sat Nov 17, 2012 5:20 pm
Sounds like a heater core to me. Do the windows fog up or do you smell coolant when you turn on the defroster?
rusty7983
Re: water leak
Postby rusty7983 » Thu Dec 27, 2012 7:47 am
Or a heater hose? Maybe its got a hole or is loose clamp on the core?
rusty7983
Re: water leak
Postby rusty7983 » Thu Dec 27, 2012 7:48 am
If you can't find it, go to Autozone and get the pressure tester they have. Fill the fluid up and pump away. The leak will be seen easily!!!!
jefe
Re: water leak
Postby jefe » Fri Jan 25, 2013 8:58 am
Yea agreed...sounds like heater core or heater hoses to me as well...
kirkland2887
Re: water leak
Postby kirkland2887 » Mon Jan 28, 2013 5:48 pm
Replace the heater hose or tighten the clamp. common sense
drofman
Re: water leak
Postby drofman » Mon Jan 28, 2013 6:05 pm
You guys know that this guy posted in Nov. of last year right? Probably fixed it already :redneck:
Mudhog1977
Re: water leak
Postby Mudhog1977 » Wed Jan 30, 2013 8:20 am
drofman wrote:You guys know that this guy posted in Nov. of last year right? Probably fixed it already :redneck:
U know I was thinking the same thing been noticing threads from years ago being commented on
jefe
Re: water leak
Postby jefe » Mon Feb 04, 2013 2:39 pm
It's nice to have a solution I guess....those searching down the road might find it useful...
Users browsing this forum: istellabot [Bot] and 2 guests
