4 wheel drive wont engage
4d4life
Post by 4d4life »
i cannot get my 4x4 to engage on my 88 bronco ii with electronic transfercase if you push the button nothing happens i have already taken the motor off and cleaned it what now?
drofman
Re: 4 wheel drive wont engage
Post by drofman »
If you have someone push to button and with you under the vehicle (Key on, engine off of couse), put your hand on the motor and see if the motor is engaging. If it is, lift the front and see if the front driveshaft will not turn (with transmission in gear). If all the before works it may be your automatic hubs.
