4 inch rough country question
i plan on doing a 4 inch rough country on my 89 b2 this next summer but my question is that rough country say that it comes with everything you nedd but i have heard you need extended radius arms is that true?
Re: 4 inch rough country question
I believe Rough country's kit comes with radius arm drop brackets. You could easily fab up some extended radius arms from the stock ones for better flex though.
It come with everything you need to install the lift. All brackets,shocks,and hardware. But the 4 forums Im part of have topics on the fact that the TTB drop bracket will punch a hole in the pumkin on the front axle if you dont install longer bump stops.
PUFF
it comes with the bumpstop drop brackets as well
