In Tank Pumps '84 vs '90
Dreded
Post by Dreded »
Ok so I FINALLY have the money to finish my second 5.0L BII install and I have a carbed 5.0 in a '90 bII FRAME/body was wondering if anyone knew if the Sending unit/fuel pump for a '84 would fit the '90 fuel tank so I can just change the in tank pump to the one designed for a carb
My other thought was using the econoline mechanical pump and hollowing out the in tank pump so it could pump through it
Or what did you do to solve this problem?
4x4'ers Eat More Bush!
Dreded
Re: In Tank Pumps '84 vs '90
Post by Dreded »
seriously nobody knows the answer? I know a few of you have done the swap so what did you do?
kirkland2887
Post by kirkland2887 »
I would just pull the pump off the in tank unit and put i piece of fuel line with a pickup screen on the metal tube. that way you still have the sending unit.
CFAIST
Post by CFAIST »
^^^^Thats what I did on my 85 Fullsize Bronco when I converted it to Carb
1989 Bronco II 2.9 5-speed, 15" x 8" Chrome directionals on 30 x 9.50 x 15 Mud Claw Radials, Next up paint time!
